RCU Forums - View Single Post - Electriflying Top Flite Stinson Reliant
Thread
09-25-2018, 07:35 AM
47
stearman65
Fin-e time.
Pinned the fin t/edge to the board, then dry fitted the ribs with the jig tabs pinned to 1/4 square to hold them vertical as per the manual. once set square, zapped the joints with cyno. Then sanded the rib noses to match the angle of the leading edge, pinned the part shaped leading edge to the ribs & zapped it in place.. Added the 3/16 square rib braces. Then shaped the leading edge skin,
TIP do this first before laying the fin parts on the plan.
Some odd angles, doing this first would have been easiest. Added the leading edge sheet & glued in place with aliphhatic. (Lunch break) Cut the template for the fin skins from the plan & made up 2 skins, the balsa quality was really ropey, will need some work later. Left setting until tomorrow if my preventative shingles jab allows.
07:38 AM
. Reason: didn't know if posted
Reply
Like
stearman65
View Public Profile
Send a private message to stearman65
Visit stearman65's homepage!
Find More Posts by stearman65
View iTrader Profile
