I embed or glue a single edge razor blade (or a #11 Facto blade) to a piece of balsa the thickness of the overlap I want and then cut the covering with the wood pressed firmly against the leading or trailing edge. You need to keep the excess covering pulled out straight from the surface to get a nice clean cut.
