Originally Posted by
ripplewave
I was simply looking for a way to use the pdf as a template to trace over. I was looking for specific menu steps, etc. I did figure it out. Thank you all for your input.
I use Draftsight instead of TC but its the same process. At Zamzar.com you can convert the PDF to JPEG image. They send you the converted file to your provided email. I use to insert the image as a background inside Draftsight and trace over the parts I want to print on card stock paper and use it as templates. Hope it helps. Alex
