The stabilizer is permanently installed now, the garolite tubes are bonded in the tail and the haves along with the aluminum tubes can be removed for storage & transportation. I need to adjust some wood on the stab as there is a bit of mismatch between the glass and the stab. The fillet between the fuse and the stab matches on the bottom side but is out on the top, nothing I can’t get cleaned up in the next night or two. I need to installed the hard points in the fuse to fasten the stabs and then I can install the tail cone. The wings are set at 1 degree positive incidence and the stab at 0 degrees. Setting the tail and squaring the wings to the fuse & stab to the wings was not fun, add the removable stab tubes to the equation and it’s even better!
