You're welcome Max and I hope you have received yours by now! I took mine out flying in the dark with a buddy that has one too and it is a ton of fun!
Here are two things to keep in mind while flying at night with this:
- It needs light in the nose to help with visibility when flying at you, so try to fly at yourself with an angle so you can see it better.
- Light motion actually helps you see it better. I thought it would be the opposite, but I was not correct.
- Red, white, and green combos are the easiest to see from what I can tell.
I hope this info helps you and others!
