I’m nearly done. I just have to install the battery tray and that’s it! I checked CG and know where to put the tray. I’ll put up some pics as I finish it up. I cut the air vent holes in the chin and belly. I didn’t cut the extra vent holes on the side of the fuse. I’ll wait and see if they are really necessary. I doubt they will make much difference.
I am using the Super lightweight tailwheel from F3AUnlimited. It looks similar to those really cool setups you get from RS or Japan but a lot cheaper.
F3AUnlimited Super Lightweight Tail Wheel Assembly (F3ATWALW)
looks like my weight with Roaringtop 5800mah batts will be 4940. These batts weigh 1285g, so smaller packs will really bring the weight down
