Hi Greg,
My wings were were built with a maximum throw as shown on the plan, inner elevators 30mm at the fuselage, Outer elevons 20mm at the wing tip and Rudder 25mm at the bottom. Dave Wilshire reduced the throws a little and the model flew fine. Unfortunately the guesstimated throws were not measured and after installing the gyro and sorting out the directions and travel, the settings were lost so will have to be guesstimated again! Will take note after the next flights.
Looking good in white! I would like to see some details about the thrust tube.
good luck with the maiden flight when it comes.
Cheers Dave
