1/36 Parts wanted - Losi Micro DT
Hey all!
I have a 1/36 Losi micro Desert Truck and recently the pinion and slipper teeth finally ate each other and are useless. I decided to use this as an opportunity to upgrade the truck but did so without doing my usual research first (dumb, I know). I wound up replacing the slipper gear with aluminum, and then mounted a Tazer 7915Kv (DYNS1405) micro brushless motor with pinion. Both fit great, and then I noticed the three prong connector on the motor - this is when I started looking for other stuff and realized that everything is discontinued. Contacted horizon and they said to look on the internet for parts - yeah, no kidding.
So, if anyone has parts that would fit help me upgrade then let me know - or if you know where to go for compatible parts. Definitely need a new esc, not sure about the servo, but I imagine so?
I like this little truck and don't want to buy another one- especially after just having bought these parts. If it is fixable, then I want to fix it.
Any other advice is appreciated as well.
Thanks in advance!
