Anyone have issues with the rudder pushrod guide tube alignment being significantly off . The long 4-40 rod binds inside the guide tube when you attach it to the rudder and you can see a serious curvature in the rod from where it exits the fuselage to the rudder attachment point . I will rework this but it binds so much that the rudder require serious force to make it move with only the rod attached , no servo attached yet . Shouldn't have to do this kind of rework on a model this pricey ! Thanks TF. I will be calling you ....
