Originally Posted by
Tip22v
Stan, if your steering servo is not being stabilized by your Cortex then you not affected by this issue. In my case my receivers are plugged into my Cortex Pro via serial connection, then serial connection from there to my Jeti Central Box power distribution unit. The way I have it configured right now the outputs to both the rudder and the LG15 (for steering) are both stabilized by the Cortex, which is not good. If I cannot figure out a way to turn off stabilization by the Cortex to the LG15 (Steering) then I will need to abandon the serial connections and use the Cable Loom that comes with the Cortex. The downside to using the Cable Loom is that it's a lot more wires (does not look as clean) and I won't be able to get Telemetry data from the Cortex.
If anyone knows how I can disable the stabilization on just one channel please let me know.
-Tom
“Teach” the Cortex Pro with the rudder/nose wheel steering mix off.
Danny
