John the steering will not be enabled until the gear sequence is completed. This can be programming including doors are taking to long. Lots of settings in that little box and one is off somewhere. I had the same problem programming the B2 because you don't fly that plane with the gear down since its so unstable with it out. You deploy it right before turning for final so I had to speed up the gear down sequence to get nose steering active in time.
