Put the RX on the bench and hook up a basic system with battery, the flap servo (s) and the Tx. Power this up and watch. See if the same symptoms occur. If nothing happens, add one more item from the plane and test again. Keep going until the problem shows itself. Last item added is probably the culprit. I expect you'll find it sooner rather than later.
