Originally Posted by
LouieB
The problem is not the farmer reporting the plane to the FAA ... a fly-a-way is not inherently illegal of itself. The bigger issue is did the plane do any damage and are you covered? The law is to have the sticker and not having the sticker gives your home owners insurance company an 'out' because you are flying illegally. So now, the claim
falls back to the AMA secondary insurance which may or may not cover the claim. That is yet, as far as I know, to be determined whether AMA insurance will cover an
incident where the aircraft was not registered or, registered and not labeled.
I asked my home owners ( Erie ) if they covered and there answer was if the plane is not registered and is being flown as a hobby it is very likely they will not cover the claim. They would likely consider it an illegal incident and not cover it. It would be up to the agent at the time. Any commercial flights and certainly they would not cover the incident.
Just as important is that not all home owner policy's will cover the RC plane. Erie happens to consider it a model so it comes under the H.O. policy. Other companies may consider the RC plane an 'aircraft' and in that case the H.O. policy probably would not cover the incident. Best to check with one's insurance agent to make certain if their H.O. covers R.C.
AMA has stated several times, that registration is NOT a requirement of your insurance, Clubs and CD's are not being tasked with verifying it, its between you and the feds, the analogy is that would be like them checking your car tags are current when you show up at the field.
BTW, what happens when you blow a light and hit a car, or cause a wreck driving DUI? Your car insurance still pays. They might drop you after, but they pay the claim.
