Hi.
I am starting to strip a Goldberg Ultimate. I would be interested to hear from guys that have done it. It has a glued on canopy and the great planes mesh style hinge material. did you cut the control surfaces off the plane and re slot the hinge? I would like to replace the hinge with robart pin hinges,can it be done easily with the bevels done?
will the canopy glue loosen up with heat?
Any tips on getting the blue ultracote that stains the wood off? the covering came off easy but it has stained the wood, head gun and razer blade scraping does good, but?
thanks
