Originally Posted by
Glowgeek
Something to note when looking at Torque & HP graphs above is that the 62 and 72 share the same cam gear. That cam appears to be much better suited for the 62, having a much flatter torque curve, allowing it to run a much wider range of props and achieve hp at higher rpms. Now here's the scary thing, the fa82 uses the same cam! This may explain why both of my 82s are so prop sensitive
that FA62/82 Cam (SAI6535A), is also used in the 100, no-wonder it works so good in the 62. it looks like a Cam upgrade would be vary easily done if Saito cared to do for the 100..
but I guess then people would be putting that upgraded Cam in their 82s, 72s, and 62s Haahaa
Jim
