Originally Posted by
jofunk
I am not a radio expert but am trying to understand. I have a few R6014FS receivers. On some of the ports the signal voltage is 2.7v as opposed to 3v on the other ports. Is there any concern about using a Y harness in a port with a 2.7v signal? Again all the equipment is Futaba. I know there are issues with some after market equipment in the lower voltage ports.
Thanks Again,
Joe
Probably not, unless you are using very long extensions with them. Then maybe, but you would know right away.
