RCU Forums - View Single Post - New Hangar 9 P-51 60cc
Old 03-23-2019, 11:29 AM
  #1629
CaptRKO
CaptRKO's Avatar
Originally Posted by Len Todd View Post
When the canopy blows back, when left open, it slides all the way back past the slide stops and hinges on the guide pin. Then the back 1" of the painted canopy cracks off. Then you have a busted canopy. I also have a backup canopy. But I am living with the repaired one for now.
On the retracts, if you inadvertently retract while on the ground, the worm gear separates from the motor. Can't get just the motor/gear. Have to buy a whole new retract at $100+. PITA when you inadvertently hit the gear up switch when taxiing or just sitting there powered up. On all my other ETracts, the current limiter would have kicked in. Apparently, ... not on this one. Not to mention if you just let the gear complete the retraction, then its sitting on the inner doors. Got to be extra careful with this setup.
Good to know on the Elite gear I will watch out for that..... I decided to omit the inner gear doors on a recommendation from a friend who works at Horizon...he also suggested adding a LIFe battery just for the gear so I did that. I am going to post my Maiden flight info/pic in the next comment.. Thanks for your input.
