fixable going to need to remove the bottom sheeting at least showing 3 rids one towards the front where the cheat spar is an same at the back..make up a doubler out of 1/4 ply an laminate it to the broken one in the front cut notches so it slides down an glue away.. with normal building skills you shouldn't have a problem fixing...looks like Kmp quality..
