The GX has a longer and more gradually tapered needle valve because the carb adjustment gets very sensitive with gas.
Also a totally different head button that increases compression and uses a hot turbo glowplug. To handle the higher pressure with gas, you need to use the special head gaskets and head lockdown screws.
That's pretty much it as far as differences. But you will also need a lot of luck and MOJO!!!
