Originally Posted by
SrTelemaster150
WHOA, WHOA, WHOA, hold your horses there pardner.
You are comparing apples to oranges.
THAT is a SB Chevy that has an adjustable rocker pivot mount. That video does not apply to any engine that has a fixed rocker pivot like our Saitos, or SB Chryslers Fords etc.
While the geometry does change, the net valve lift will not change a significant amount when the change is at the pushrod/rocker interface . As long as there is sufficient adjustment available, there would be little benefit in changing pushrod length.
I believe I said that to Pete in a reply
Jim
