Originally Posted by
Captcrunch44
Glowgeek
30% nitro in a high compression 180? Try FAI fuel (0% nitro) or maybe up to 10%. Having high compression advances the ignition timing and doesn't require high nitro content. You could be experiencing detonation using 30%. Check your glow plug for a deformed coil and/or little bumps on the wire.
Things that advance ignition timing in glow engines:
Higher compression
Hotter glow plug
Higher nitro
Higher oil content
Higher prop load
Try 30% nitro
O'Donnell Speed Blend with 8% oil in an FA-180HC running CDI
Holy moly will it howl! Hit nearly
9000 RPM with an 18 x 8 Dynathrust prop.
Boy oh boy was it ever thirsty though.
