RCU Forums - View Single Post - Prop mounting
Thread: Prop mounting
Old 04-04-2019, 12:07 PM
Fly4Funn
My Feedback: (14)
Default Prop mounting
Just got a Moki 215 and bought a couple 32X18 props for it. One was a SEP and the other a Xoar. Both prop hubs are thicker than the prop shaft stub on the front of the engine so when I put the prop on, there is no shaft sticking out for the plate to slide onto. Is it a must to have this shaft sticking into the hole in the front prop plate or just mount with the prop bolts and move forward. If it does need to stick into the front plate, how are you guys handling this when there isn't enough shaft to reach through the prop.
Thanks in advance for any suggestions.
