RCU Forums - View Single Post - Prop mounting
Thread: Prop mounting
Old 04-07-2019, 07:37 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
I would not run an engine of that size without the prop washer engaged onto the spindle. I think the only choice you may have is to locate/adjust prop size so that you find a prop with a thinner hub. Can you go larger diameter and less pitch? Have you contacted Moki to see if a longer spindle nut is available?
