RCU Forums - View Single Post - Prop mounting
Thread: Prop mounting
Old 04-23-2019, 04:08 PM
kmeyers
kmeyers's Avatar
I'm going to assume that you will be using a spinner and that the shaft is threaded to attach it. I would use a spacer the shaft dia. drilled for the spinner bolt with clearance and use it while mounting the prop washer to center it while torquing the bolts.
