hot antifreeze,
you can remove the antifreeze with WD40, then rinse the WD off the case with rubbing alcohol. I rinse the bearings too with R-alcohol, then oil once the engine is back together I oil it,
if the case comes out a bit grey from the antifreeze don't worry about it, just rub the WD into the case and the grey should go away
Jim
