Tune the needles better. I had the same engine in a P-51 and could not get it to run. I reset both LSN and HSN, and got it to run so well it wouldn't shut off. Also check the tank position, it may be too high which is causing it to get too much fuel. Easy way to check, drain the tank, and fill it less than half and see how it runs. Do this first and see.
