Originally Posted by
Rudolph Hart
CDRC the above is very good advice,we've all done a flying tune (very different from running it on the bench) on a saito inverted in an arf with a high fuel tank position and there are many things you can do,so you end up with a smooth and powerful saito in your arf?? if you answer some of the above questions in a bit more detail it's easier to help you,pics are good too.
ps jim the small fine white fibre is not plastic,i use dubro or sullivan tanks and good fuel line.
Hey Pete, what about that filter you say you have for your pump, could the hairs be coming from that filter, or even the pump it's self ?? I have a filter for my gallon jug and it's not metal, check that filter
Jim
