hey guys, about my Carb dram LOL. even just a little pressure from the screw and the barrel get's harder to turn, and I also tested it by removing the manifold and the same results.. then I mounted the 100"s Carb to the 82's plastic back plate, and the same thing but not as bad.
so, with the 100's metal back plate I can not tight the Carb enough to hold it secure so I guess I have to send the Carb back, if I can find the receipt
Jim
