Gluing angle aluminum to the vertical spine.
So I did the math to put the float step 2” from CG and figured out where the main landing gear and the slot I built into the fuse would line up with the floats.
I cut 3” section of aluminum angle for the rear and 4” sections for the front, roughed them up with epoxy and glued them.
