Originally Posted by
jet-lover
Here's the specs of the K45G3.
Do you know the residual thrust?
Diameter: 62.9mm
Length: 160mm
Weight: 450g (Include internal valve, mount, digital control system, FOD
screen)
weight with peripheral 516gr
Max. speed: 225 000
thrust: 4.7kg + @ 15 ° C and 4.4 kg at 28 ° C
EGT: 720 ° C max
Fuel: Jet A1, Kerosene
oil: 5%
These specs don't look correct, on the published FB video the idle thrust is 2,6N at 75.000 RPM and full power is 42 N at 234,000 RPM
JB
