RCU Forums - View Single Post - Glider Crash....Fixable?
Old 06-21-2019, 08:32 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
A little glass, a little epoxy resin. It can be glued back together after you sand the fuzz off the fracture with CA. Then sand the inside well with 220 grit, clean, and apply a few layers of 3oz fiberglass with epoxy laminating resin. Make each layer just a little wider then the previous. You double then sand the outside smooth, apply a single layer of 1.4oz cloth over the break, feather sand the edges and reprint. Done right it shouldn't add more then an once of weight. If you choose to do the repair you can PM me your address and I would be happy to send you the required cloth. The repair can be documented here, I will talk you through it and then others will have access to the information.
