Originally Posted by
DHC6
I use 120 PSI for my gear. Unless you have separate tanks and valves, you can’t have different PSI front and rear. 120 PSI works well for my setup.
DHC6... maybe you were thinking for the retract of the landing gear ? For that, I also use 120 PSI. I was referring to the pressure inside the landing gear after you have filled them with oil
