Old 07-31-2019, 02:38 PM
planenutzz
Tail feathers on. Will start looking at the engine mounting next. Will use the distances I have with the Evo 33 in my RV-4 to work out the firewall to prop hub distance that is required as the Evo 33 is one the engines used in this Fokker and has set length standoffs supplied.
I intend to get some rubber isotaion mounts that will mount to a 4mm alluminium plate and then onto the firewall. The G38 will then bolt to this allow plate. Thi is the set up I have with same engin in my 90" Spitfire and it works very well.
