The reason I ask is I had same problem with jeti assist rec in a bvm plug and play viper with king tech turbine.it only affected tail servos. I found the smoke tube rubbing on turbine to be the problem. It would only do it on run up. Removed smoke tube and all went away. Hope you find your problem.
