Originally Posted by
VincentJ
Sorry for how Sig treated you Steve. If the rib is already in place, just get a 1/4" drive deep socket that's the right diameter and wrap it with sandpaper, the kind that you use on your sanding bars. Then insert and slide back and forth until the hole is in proper alignment.
Now he tells me!
You are certainly good at coming up with slick ways to build. I didn't think of that for the existing built wing half. I used a blade to cut from a precarious angle. It looks horrible but that portion of the wing is covered in sheeting anyway so in the end you can't see it.
The right wing half is not started so I plan on cutting the holes BEFORE I do anything with them.
