And after I got the left panel built, I realized i didn't cut any lead throughs for the servo wires in the ribs and went back to the trusty ol laser and within 20 minutes had 12 reinforcements cut out from 1/32" plywood.
Don't know why some of these came out blurry.
Next step on the lower sing is to build and cut out the ailerons, then go over all the glue joints one more time, add any webbing as needed, since I think I missed a few, then epoxy the end panels to the center section so I can fit it to the fuse. Once that is done then I can set the tail section, form the filet over the lower wing and sand the fuse to shape.
The laser is coming in really handy as I can quickly make parts that are not part of the kit, or the plans, such as the servo hatches for the wings, the reinforcements above, and anything else I may need as I build. Best part is I have the parts saved so I can quickly and easily reproduce them if I ever were to create a short kit.
