Old 08-18-2019, 02:41 PM
planenutzz
Good progress on the Fokker.Couple of small jobs to finish. Muffler to fit when it arrives. Battery packs should be here this week. Eneloop 2500mA/h 6V packs x 2.
Gaskets to engine and carby to fit, throttle throw to set.
All other systems are in, ailerons have differential programmed and expo on elevators, rudder and aileron. I have a bit of aileron to rudder couple mixed in too.
Did a quick balance check and it is slightly tail heavy with cowl and prop off. Battery packs will fine tune that so looks like no extra weight in the nose will be required which is very good news.
ID:	2265084Click image for larger version
ID:	2265086Click image for larger version
ID:	2265088Click image for larger version
ID:	2265090Click image for larger version
