I'm trying to set up my (new to me) 8FG Super so that the switches to control things are in the same location as they were on my 7C which I've been flying with for almost 10 years (once you reach those "golden years", change comes hard). To that end I have attempted to put flaperons on switch SG (3 position). With flaperons set at 15% and 30%. Went to CAMBER MIX and assigned switch SG. Activated so that its OFF in UP position, ON in CENTER position and ON also in the DOWN position. Then went to the CAM (AIL) setting and set AIL to 15%/30%, and AIL2 to 15%/30%. In the UP position of switch SG nothing happens. Good. In the CENTER position nothing happens (?), but in the DOWN position both ailerons do in fact deflect downwards and I can control the amount of down by adjusting RATE2. Can you give someone give me a push in the right direction please.
I did read this post, but it didn't help:
http://www.rcuniverse.com/forum/rc-r...lp-please.html
