Originally Posted by
TexasFlash
You can eliminate 1 servo at a time and see if it ever clears up. I would suggest a lower voltage battery to eliminate the regulator as I suspect it as most likely guilty.
thanks dear friend for your reply
But
You say the regulator is base of the noise?
