RCU Forums - View Single Post - Yellow Aircraft Stingray
Old 09-12-2019, 05:44 PM
Kelly W
Hey George,
Interestingly enough.... A few flights before I buggered up my stingray on landing, I'd switched my elevon servos to Hitec 5945MG's. I had a lesser quality digital before that. The 5945's had superior centering and hysteresis performance, which really dialed in the trim. It was a totally different jet. I'd suggest going without the AS3X stuff until you have a 1st flight down, then judge if its still needed. I thought it was dutch roll, but it went away after the elevon servo swap. Before that change, it was a real handful, particularly if you let it get far away. If you focus on gettign good servos, it may be a non issue.
Also, ditch the stock gear and install the equivalent Robarts. My gear got really sloppy - fast, and that was a contributor to the hop + damage... With a robust gear set, you only need to concentrate on holding the nose up slightly on landing, and just let it settle in at idle with the speed brake up. Its a very slippery jet, but its OK...
KW
