Originally Posted by
ledesma45
I'm going to try it at the field and see if i get anything out of there, i will put a napkin to see it getting wet or not.
I wouldn't run it much if you are not getting oil out of the front vent, you do not want to destroy that front bearing and cam. and I am wondering if you are getting more oil in the rocker cover because the oil is not getting to the front, here are a couple things to try,
try removing the nipple to see if something is blocking the vent hole on the inside of the case,
another thing, you can try priming (with oil) the front of the case thew the vent hole
edit, with all this twin talk I had to get my 100 Twin out and put it on the desk by my monitor
Jim
