RCU Forums - View Single Post - Yellow Aircraft Stingray
Old 09-28-2019, 12:22 AM
Kelly W
200 m on concrete should be be fine. I flew the 1st 2 flights of a 500ft long grass strip.
Honestly, I wouldn't worry too much about trailing link struts. The legs are pretty short, and the spec'd robostruts will work fine. I'd just go with that and change later if you feel the need for it. I doubt you will though.
I did modify the nose strut though, to use a single nose wheel.
KW
