It's not that big of a deal to drill new holes. I would however suggest that you move the linkage to the outside hole on the horn. Replacing the clevis would not be a bad idea as well. Make sure if you do replace the clevis to get the ones that fit the 2mm threaded rod. It is also common practice to slip a peice of fuel tube over the clevis to keep them from opening.
