First thing to check is that you have the model in the same orientation as when you setup the AS3000. When you turn on the model with the AS3000 it takes longer to hook up with the tx, up to about 8 seconds IIRC. If that doesn't work, disconnect the AS3000 and see if everything works correctly.
