Originally Posted by
CARS II
On the Kangaroo because the engine is mounted so high the engine has to be mounted with the rear up to help it rotate off the ground, you may have have to do the same to some degree, it may end up with some, not much or nothing.
Thing is I have no drawings of the thrust line vrs longitudinal axis. So have no idea of the aircraft had any upthrust.... I know it need reflex like the hotspots, but upthrust?
