Benchmark Prop:APC 15 x 6 @8800 rpmBore:1.25 in (31.7mm)Carb Type:2 NeedleCrank Type
ual Ball BearingCrankshaft Threads:M8 x 1.25mmCylinder Type:AACCylinders:SingleDisplacement:1.15 cu. in. (18.9 cc)Engine (Only) Weight:20.6 oz (585 g)Mounting Dimensions:115 x 60 x 110 (L x W x H) crankcase - width 40 / mounting holes - 50 OCMuffler Type:CastMuffler Weight:2.89 oz (80 g)Prop Range:14 x 8 – 16 x 6RPM Range:1800 to 10000 rpmRecommended Fuel:GlowStroke:.94 in (24mm)Total Weight:23.49 oz (665 g)
The 100 turns a 15 x 6 faster than their bench mark.
Horizon's specs for the 115 are somewhat surprising, I just ran 14 oz of fuel through my new to me 115
This engine is clean running throughout the entire rpm band. It has so much compression, I chickened out on using the chicken stick and went straight to the starter. The Sullivan Hi Tork turns it very well. The chicken stick would have notched the backside of the Xoar.
Saito ======1.15-a
Fuel=======Wildcat 10%/18% full syn.
Plug=======New Glow Devil 4c for Saito/Enya
Prop======Xoar 15 x 8
Exhaust=----Stock 1.15 cast muffler
Max rpm @ half tank==8,340
Idle rpm @ half tank==1,990, LS needle was perfect as received.
For some reason posting makes an awful mess out of the specs.
