Global Jet Club sells this jet now. Here are the recommended numbers:
There should have been 2 wooden plates included to slip over the spar between the fuse and wing to hang the jet to balance.
The plates will give a Cg at 330 mm which works just fine.
Aileron
H – 25 mm
M – 20 mm
L – 18 mm
Elevator
H – 30 mm
M – 20 mm
L – 15 mm
Rudder
20 mm
Flaps
Mid 50 mm
Full 95 mm
Crow
13 mm
Cg
305 mm – 330 mm
