Nano X worked out great.
Nano X Cox TD .051 3rd Flight Tuned Pipe APC 4.3 x 5.5N Speed Plane Last two passes are the best peak: 28,181 rpm / 147 mph Prop Pitch Speed
Now the fastest TD .051 3ch plane on You Tube - bested Nano III now in 2nd Best static 21,962 rpm / 7.1oz thrust / 115 mph pitch speed / Pipe at MRP 7.5"
.144 hp - 107.4w / 7.1 oz thrust / stock piston /cylinder and crank! 25" span 75 sq. in. wing / 8.2oz RTF / Temp 87F. dry, winds 7 - 12 mph. 25% nitro / 20% oil
SPI engine / no pressure tap. Kamtechnik turbo plug adapter & prototype manifold / header O.S. 7 plug. No mods to cylinder, piston or crank. Only add odd
aftermarket parts and no high nitro just off the shelf 1/2A Fitz fuel! This is the fastest Cox 1/2A RC 3 ch plane on youtube due to many attributes all contributing
to the top speed thru design / size / weight / power and quality Kamtechnik components.
