Originally Posted by
Pcomm1.v2
Though, a better Leo 2 transmitter solution was reached months ago, but prefer a dedicated transmitter.
Nope. When it first came out, you were insisting that anything other than a FM radio would not work, and even if it did, that the GBS would not work with it. You were the one persisting that the Leo2 will not work with anything other an FM radio till last month when I showed you that it works with a 2.4 ghz attack. This post is basically proof from me to kill off more of this misinformation.
Also, for the same cost, you get a infinitely superior radio with 6 channels that can control tanks, boats, helis, quads, planes on the fly on both mode 1 and mode 2. Plus, you can set the firing switches are on the right to fire on the fly, while moving both the tanks and the barrel, like it does in real life, whereas the Tamiya ones has switches on the left in an akward spot. You need to stop, aim and shoot WWII style. The Spektrum is a no brainer if you can spend 45 minutes to set it up.
