RCU Forums - View Single Post - Blade 130s Int/3D Flight Modes - Full Throttle
Old 11-08-2019, 07:52 PM
dzydvl
In intermediate and agility modes it is going to give you a constant head speed and you will control the pitch with left stick. Turn on the throttle hold so the rotor will not spin then put it in intermediate or agility mode. Now move the left stick up and down you should see the rotor blades changing pitch from positive (stick up) to negative (stick down) this is what give you the ability to fly inverted. Once you see what it is doing input a bit of negative pitch, turn the throttle hold off, this will start the main rotor, then lift off like you would normally. Just remember if you panic and pull the stick down it will go negative and come down really fast. Take your time.
